Login Error
Close
How to Locate the Water Shut Off Valve
by DoItYourself Staff
what you'll need
  • Sharp pole
  • Map of your land
  • Transmitter
When you are a home owner, it is important that you know where to find your water shut-off valve. When a water pipe springs a leak, you need to access this valve quickly in order to prevent the flow of water to the leak. It is also necessary to distinguish between the local authority water shut off valve, and the one which supplies water to your home.
Step 1 - Finding Your Water Shut Off Valve
You have two choices when it comes to locating your water shut off valve, either doing it yourself, or paying a locating company to come in and perform the task for you. The latter usually charge a lot of money, and use a pipe locator to find the pipes. Even then, they may not be completely successful.
Step 2 - Doing it Yourself
If you want to do it yourself, then you should begin by finding curb stop keys, which are used for stopping water to an outhouse or yard. Work backwards along this line, looking for more pipes. Use a sharp pole to penetrate the ground, not pushing too hard in case you break the pipes. You can also use a transmitter to locate copper pipes.
 forum activity
