Login Error
Close
How to Locate Your Windshield Rain Sensor
by DoItYourself Staff
If you want to use your windshield rain sensor or find out if you have one on your vehicle, you will have to know how to locate it. Follow the steps below to determine whether you have the safety measures that you need when it starts raining. The rain sensor looks like a small metallic black sticker on the windshield, and the control box is a plain black box on the inside of the vehicle that control the sensors commands. Both of these parts are essential for the sensor to work correctly.
Step 1 - Checking Inside and Outside
Depending on the make and model your vehicle, you will want to search all areas of your windshield to find out where the sensor is located. It may be on the inside of the car, on the windshield. In this case, it will probably be towards the top, but can also be on the bottom. Make sure to check each one of the 4 corners to see if it is there.
If you do not find the sensor inside the car, look on the outside. It is usually located on the top of the windshield for quick; accurate read outs of when it starts to rain and your windshield needs to work. Make sure to check each one of the 4 corners on the outside of the windshield. This is the most common place that the sensor will be in.
Step 2 - Locating the Sensor
Since you have gone all the way around your windshield from the inside and the outside you should have came across your sensor. It is a large circular area in black. This will allow you to not have to worry about the windshield wipers while driving if it starts to rain. It will be able to turn them on by knowing that it is raining. The sensor should be intact, on your windshield, and it will not be protruding so do not look for a large lump or something coming out from your windshield. It is more like a sticker that is shiny with a small bump.
This sensor has been an added feature to many of the newer cars and trucks that have come out. It is to help prevent road accidents because of natural disasters. They want to make sure that you’re safe while driving your vehicle. If you are having a hard time locating the sensor, your vehicle might not be a equipped with one. You can find out if you have a rain sensor by checking your vehicle’s handbook.
You should be able to see all the extras that came with your vehicle or that you can use to upgrade it. This allows you to have the choice on whether or not you would like to have the rain sensors installed into your vehicle. You can learn how to troubleshoot, fix, and replace the rain sensor on your own in order to save money if you read about changing and replacing sensors. This allows you not to have to call a professional in.
 forum activity
