Login Error
Close
How to Loosen Tight Motorcycle Gloves
by DoItYourself Staff
There is only one real way to loosen motorcycle gloves and that is to wear them, ride with them and let time make them fit properly. Many people have tried other methods to little or no avail. Getting them wet or steaming them has proven to have little effect in altering the fit.
The best way to get a good fitting glove would be to try a variety of styles on before you buy. The gloves should feel comfortable on the finger width and length and tight across the palms. Within a month or so of wearing them, they will stretch and fit comfortably. If you buy the gloves too loose, you will find yourself in need of a new pair much earlier than anticipated.
Motorcycle gloves are an important part of your motorcycle gear as they provide protection from the weather – hot and cold, they give you a better grip especially in wet weather and they protect your hands from cuts and bruises in the case of an accident.
It is important that your gloves fit properly. If the fit is not comfortable you won’t enjoy your motorcycle ride. When buying new gloves you will need to keep in mind that it may take a few months of wear and use for the gloves to get to their most comfortable fit.
 forum activity
