How to Maintain Bathroom Vents
what you'll need
- Knife
- Dry cloth/towel
- Drill/screwdriver/wrench for disengaging the fan
- Toothbrush/small paintbrush
- Vacuum cleaner
- Metal tape
- Caulking mixture
- Retailed motor oil
Systematic maintenance of the bathroom vents is critical for ensuring proper air circulation within the bathroom. If the vents are underperforming, the moist air tends to accumulate within the bathroom and the moisture gradually seeps into the walls and bathroom cabinetry. Moisture retention is a major reason for mold growth in domestic bathrooms. Neglected bathroom vents are unable to expel foul odors from the bathroom.
Understanding Bathroom Vents Maintenance
Bathroom fans need minimal maintenance, just once, every 6 months. Maintenance issues arise as bathroom vents are constantly exposed to a moisture-rich environment. Further, the exhaust fans gradually develop a layer of dust particles and grime. If the dust coating is left unattended for too long, it can damage the fan’s motor unit. Grime build-up is also the main reason for bathroom exhaust fans becoming noisy over a period of sustained usage. It should be understood that maintaining bathroom exhaust fans is easy, requiring negligible technical knowledge. A comprehensive bathroom-vent maintenance regimen consists of cleaning the bathroom venting and checking their functional efficiency.
1. Basic Maintenance of Bathroom Vents
This procedure is for thoroughly cleaning the vents.
Disengaging Bathroom Vents
Turn-off the exhaust fan and pat it with a dry cloth. Unscrew and remove the fan’s grill. Sometimes the fan’s outer plate is embedded within the surrounding wall. You need to loosen it with a knife. Ideally, you should remove the fan along with the metal bracket that encases it. This helps you observe the fan’s assembly system, making it easier to re-assemble the fan after cleaning. This also makes it easier to disconnect the wires. Pull out the fan unit and unscrew the metal screws holding the metal bracket. Unplug the wires that have been hardwired into the motor unit.
Cleaning Bathroom Vents
Place the blades and the motor on a dry towel. You can use an old toothbrush or a small paintbrush for scraping-off the dirt. However, this only cleans the top surface. Use a vacuum cleaner with a small nozzle attached to the hose for sucking-out the sticky debris. Prepare a tubful of cleaning-mix consisting of water and bathroom/kitchen cleaners. Soak the disengaged air vent parts into this solution. This is the best way to get rid of tar-like debris and mildew that is found along the insides of the blades. Take out of venting components after 10 minutes. Wipe each part with a sponge. Dry the parts with a dry towel. Let them dry in the sun or in a dry part of the house for at least 2 hours. Carefully, reinstall the fan unit.
2. Functional Maintenance of Bathroom Vents
This involves conducting basic checks/repairs to ensure that the vents are performing appropriately.
Ensuring Stability of Air Vents
Bathroom vents are installed by making small openings along the upper reaches of the ceilings. Due to constant moisture seepage, the concrete lining around the fan’s frame can loosen, causing air leakage. This disrupts the expulsion of air from the bathroom’s interiors. Air leakage also allows hot air from the outside to enter the bathroom. Gaps along the fan’s installation frame can also induce vibrations within the fan, making it noisy. You need to ensure that the fan is held firmly in its place. Use metal tape or a caulking mixture to fill-in any gaps or crevices around the venting unit.
Ensuring Basic Lubrication
Oiling is needed for maintaining basic lubrication. This helps the motor to function quietly and efficiently. Carefully, put some drops of motor oil along each end of the motor shaft. You can ask a hardware supply store for the appropriate motor oil according to fan’s brand and blade size. Some motors even have dedicated oil-holes for precise oiling.
