How to Make a Custom Outdoor Grill Grate
If your outdoor grill requires a grate that is larger or smaller than standard grates, it may be necessary for you to either order or create a custom one.
Measuring Your Grill
Measure the area of your grill that you would like to cover with grates. Decide how many grates you would like to have cover that area and divide and measure each individual area. If you are still unsure if your measurements are correct, cut our pieces of cardboard with your exact dimensions and lay them out to make sure they cover your grill exactly as you would like them.
Consider creating smaller pieces for easier cleaning. If they are smaller and more narrow, they will be able to fit in your kitchen sink easier and you will be able to make sure that all the grime and burnt food is washed away, making it safer and easier to use your grill on future occasions.
Higher and Lower Grates
Make sure to distinguish between higher and lower grates. Some of these need to have specific markers on them so that they will stay up where they are meant to and will not fall on lower grills or into your fire. Make sure to write down exactly where the markers will be so that you will not make any errors in ordering or creating the grate.
Ordering a Grate
Many shops that sell fireplaces or outdoor supplies will be able to take orders for creating custom grates. This is convenient if you can afford it, as they will be able to make a quality product that will last for years and will look and function as a grill. You will also have a selection of materials to chose from to create your grill. Custom grills can be expensive since they are made specifically for your grill, but it is worth the extra cash.
Preparing to Make a Grill
In order to make your own grill, you will have to purchase some metal smith tools, such as a very powerful soldering iron and a saw that will cut through metal. You may also need a way to heat or bend your metal.
Purchase metal rods that can withstand extreme heat and are not painted or coated. You will need enough rods that you will be able to cut the to the length of each grate and be able to set them side by side about ½ to ½ inch apart until you have the width of your grate. You will also need some for the bottom of the grate that will hold all the rods together.
Make sure that the rods are skinny enough that they will properly grill your food, but that they are also strong enough to withstand the weight and heat of your food.
Cut most of your rods to the length of your grate size and 3 or 4 rods that is the width of your grate size. With you soldering iron, place a metal that will melt where the bottom and top rods will meet and solder them together. Do this with each rod connect each top rod to each bottom rod.
