Login Error
Close
How to Make a Homemade Boat Propeller
by DoItYourself Staff
what you'll need
  • Sheet Metal - Either Aluminum or Stainless Steel
  • Tin Snips
  • Saw Capable of Cutting Metal
  • Paper
  • Tape
A boat propeller is the most important part of the propulsion system of your boat. These are spun around by the boat engine and will propel the boat through the water.
Propellers for boats can be very expensive. However, if you have the right tools and materials available you will be able to make your own boat propeller for a fraction of the cost.
Step 1 - Choose Your Material
First, you will need to think about the material that you will use to make your propeller. As all propellers will be submerged under the water you will want to choose a material that is resistant to corrosion. Your choices include stainless steel or aluminum.
Aluminum is only suitable for use in fresh water because it will still corrode in salt water. Stainless steel is the material of choice, although it will be harder to work with.
Step 2 - Planning Your Design
You will now need to plan the design of propeller. You can choose either three or four propeller designs. You should draw these designs on paper first. Whether you decide to use three or four blades will depend mainly on whether you are interested in speed or handling.
Spend time designing the right type of propeller for your needs. You will also need to make sure that you're using the very best material for the job.
Step 3 - Cutting the Metal
The easiest option will be to cut a circle the size of a propeller out of the sheet of metal. You will find this easiest if you go to a friendly fabrication company who will cut a circle out of the metal. Once you have the circle you can then start by marking the design of the blades on the metal. Now you can use the metal saw to cut the propeller out.
Step 4 - Forming
Bend the propellers out slightly to take the shape of a propeller. You can do this by hand or by putting it in a vice.
Step 5 - Welding
Now you need to weld the finished propeller onto the shaft. You could make this easier if you use an old propeller and cut off the propeller end. Your welding skills will need to be pretty good. Otherwise the propeller will fly off or not work properly.
You might want to experiment with welding before you attempt to weld the propeller onto the shaft. Make sure that you do this very carefully.
Step 6 - Balancing
It's important to balance your propeller, because otherwise it will shake when it's spinning around. This is a very difficult job to do and you might want to get professional help. Otherwise, you can put the propeller on a motor and spin it around. If the propeller isn't balanced then you can weld weights onto different sides until it is perfectly balanced and revolves without vibrating.
 forum activity
