How to Make a Magnetic Drain Plug
what you'll need
- Metal Brush
- Micrometer
- Drill Bits
- Oil drain plug
- Neodymium magnet
- Vice/C-Clamp
- Weld (JB)
- Drill Press
Prevent accidents on the road by being an attentive driver, but prevent motor problems by making your own magnetic drain plug. When it comes to do-it-yourself, or DIY, usually there are tools all ready in existence to help out with nay problem. Also, most DIY tasks are to fix an area or prevent further damage from wreaking havoc. However, when it comes to helping your car, there are a plethora of preventative DIY tasks and measures.
The engine of every car will, throughout is hopefully long life, shed tiny flakes of metal. Much like the drain plug itself, a tiny part of the car, every small feature is just as important as the large ones. In other words, do not underestimate the damage supposedly insignificant, or tiny, metal scrapings can present. Damaging the motor, these “tiny” pieces of metal will cost you anything but a tiny amount of money. However, you can do something to prevent this damage from resulting—placing a magnet. A simple yet effective magnetic drain plug will pick up almost all shards of metal shed from the engine.
Step 1 - Prepping
The first step in creating something new is using something old, so acquire a normal oil drain plug. Raw materials are not needed to create something entirely new. Clean this drain plug as well as you can, for every part of dirt, grime, and gunk may affect the end result’s effectiveness. Use the metal brush to get the best results. Now, measure the magnets. Then, locate a drill bit that is the exact same size.
Step 2 - Getting Started
Punching a hole into the drain plug will prevent it from wandering about. Now, drill a hole into the drain plug deep enough for the magnet to stick out just a bit. Now, clean out all the metal shavings.
Step 3 - Finishing Up
Place some adhesive into the hole that was just drilled. Place the magnetic in said hole. Note that if the created hole is still too small, use the C clamps to press it in. Fastening the magnetic as tight as you can will ensure safety. For example, if the magnetic were to get loose, it would stick onto any nearby part of the car. So, if the magnet were to attach to a moving part, the car could seize, creating a high chance that an accident may result. Best case scenario, the magnet attaches to something strong enough that oil begins to leak or the magnet simply falls and oil begins to leak that way—leaking oil may be hazards to fellow drivers on the road who may skid and slip on it potentially into an accident, but it will safely halt your car slowly as the automobile simply runs out of oil. However, the loss of oil, if abrupt enough, may lead to a serious situation for yourself as well. When it comes to driving, safety is a concern not only for your car, but for the cars surrounding it, as you affect them just as they affect you.
