Login Error
Close
How to Make a Metal Bar Stool
by DoItYourself Staff
what you'll need
  • Measuring tape, pencil and paper
  • Metal bars, wide and narrow widths
  • Swivel mechanisms, half or full circle
  • Screwdrivers, screws and retainers
  • Seat cushion bases, 1/8-inch plywood
  • Solid foam rubber cushions
  • Upholstery fabric of your choice
  • Industrial stapler
  • Welding torch and gas tanks
  • Welder's safety mask
  • Flame-retardant gloves
Get your family into the kitchen to dine casually with metal bar stool seating. You can make your own custom metal bar stools with inexpensive yet durable materials. Follow the guidelines below to construct unique metal bar stools that bring both style and comfort to your kitchen decor.
Step 1: Decide How Many Bar Stools You Wish to Make
At a kitchen island countertop, you may want just 3 or 4 metal bar stools. At a tall cantina-style table, surround it with up to 8 metal bar stools.
Step 2: Measure the Bar Stool Height and Cushion Depth
Measure from the floor up to 10 inches below the lower lip of the countertop. This is the total height of the bar stool plus its cushion. Allowing for a cushion depth of 3 to 4 inches, measure the height for the bar stool frame, from the floor to either 13 or 14 inches below the countertop. This is how tall the frames must be for comfortable seating.
Step 3: Choose the Style of Metal Bar Stool to Make
Based on your measurements, choose the style of metal bar stool you want to make. It can have a round, square or octagonal seat, and operate with a half circle swivel of 180 degrees or a full swivel of 360 degrees. Choose a bar stool with a seat back for swiveling stools. You can also choose a fixed style, with no swivel at all. These stools can be backless. Choose the metal finish, which should match the other metal hardware in your kitchen. As well, select your cushion fill shape, depth and fabric to cover them. Allow twice the diameter or width of the seat cushion top for upholstery fabric.
Step 4: Cut the Bar Stool Frame Pieces and Construct the Seat Frame
Cut all the leg pieces and the horizontal supports to the lengths desired. Construct the seat frame from the horizontal supports. The legs, swivel mechanism and the seat base will be attached to it, so weld it securely.
Step 5: Weld the Bar Stool Frames Together
Weld the lower legs and footrest crosspieces together next. Add the seat support crossbars so they quarter the external frame. Attach the swivel base securely to the top of the frame, with screws and retainers.
Step 6: Assemble the Seat Cushions and Attach to Swivel Bases
Measure and cut the upholstery fabric carefully to allow at least 4 inches of overlap at the bottom of each cushion. Wrap the fabric snugly around each foam rubber cushion and its plywood base. Staple the fabric firmly to the plywood base with at least 1 staple every 2 inches. Screw the seat cushions to the swivel bases through precut screw holes in the swivel plates.
Step 7: Attach the Bar Stool Backs
Align the bar stool backs with the swivel bases and screw them to the bar stool seats. Place retainers on the screw spindles to hold the screws tightly.
 forum activity
