Login Error
Close
How to Make a Multi-Catch Rat Trap
by DoItYourself Staff
what you'll need
  • A bucket
  • A drill
  • Drill bits
  • Wood dowel
  • A pop can
  • A hammer
  • A steel punch
  • Adhesive
  • A caulking gun
  • 2x4 board
  • Carpet
  • Water
  • Peanut butter
  • A knife
A rat trap is most effective if it is designed to get rid of more than 1 of these pests at a time. Traditional poison solutions kill the rats, but leave the dead animal to decompose. You can build your own multi-catch rat trap, that will both trap and destroy rats. You can than dispose of the dead animal properly.
Step 1 – Safety
Be careful using power tools. Be sure your drill is turned to the off position before you plug it in. Store your power tools in a safe place when you have finished using them. Always keep them out the reach of children. Remember to wear suitable protective equipment, such as goggles and gloves, whenever power tools are used.
Step 2 – Preparing the Bucket
Insert a ½ inch drill bit into your drill. Use the drill to create 2 holes in your 5 gallon plastic bucket, just above the handle hinges. Slide a 14 inch piece of ½ inch dowel through 1 of the holes. Rest the other end of the dowel in the bucket.
Step 3 – Preparing the Pop Can
Use an empty soda can for your rat trap.  Position your pop can on a flat surface, so that the opening is facing downward. Use your hammer and a ¾ inch steel punch to make a hole in the bottom of the can. Position the steel punch in the center of the bottom of the can. Hammer the punch through the metal of the pop can to make the hole.
Step 4 – Connecting the Pop Can
Position the end of the dowel that is resting inside the bucket through the holes in the pop can. Slide the dowel through the other hole in the bucket. Position the can in the middle of the dowel. Spin the can on the dowel.
Step 5 – Adhering the Carpet to the Board
Insert a tube of adhesive into your caulking gun. Apply a bead of adhesive along the board. Your board should a 24 inch long 2x4. Stick your carpet to the board. Your carpet should be 4 inches by 24 inches. Position the carpet with the shag facing upward.
Step 6 – Positioning the Carpet Board
Position your carpet board with 1 end leaning against the bucket rim and the other resting on the floor. Face the carpet upward. The carpet board will be the bridge to the bucket.
Step 7 – Setting the Trap
Use your knife to cover the pop can with peanut butter. Position the trap in a spot where there is evidence of rat life. Fill your bucket with 2 gallons of water. Be sure to place the bucket in a place that is out of reach of any small children or pets. The rats climb up the bridge and onto the dowel to get the peanut butter. The can spins around, and the rat falls in the water.  Check on your trap periodically. When you have caught your rats, be sure to dispose of the rat bodies properly.
 forum activity
