How to Make a Noisy Electric Fireplace Quiet
what you'll need
- Wrench
- Screwdriver
- Hammer
- Cleaning materials
- Lubricant or industrial oil
- Multimeter
An electric fireplace will give you the charm of a real wood-burning fireplace, but without hassles of ashes and soot. Electric fireplaces create visions of fire with the corresponding crackling noise inherent in traditional fireplaces. But although the crackling noise may be soothing and calming for some, other kinds of noise that an electric fireplace will exhibit through years of wear and tear are not.
Step 1 – Check the Hardware Connections
Most of the time, the reason why an electric fireplace is so noisy is because of loose hardware. You want to check the screws and see if they are screwed in tightly. If not, take your trusty wrench and screwdriver and tighten the loose connections up. Try the fireplace again and observe of any changes.
Step 2 – Check the Tubes
Another reason for all the racket is bent tubes. Tubes bend through time and when they do, they often produce a rattling noise. This could be because the tubes are banging with the other parts of the electric fireplace. Visually inspect your electric fireplace for any bent tubes. If you see any, simply re-bend the tubes with the use of a hammer.
Step 3 – Check the Blower
Another reason for the noise could be that the blower in your electric fireplace has loosened or has been completely out of balance. That usually happens when your blower accumulates a lot of lint. A simple cleaning of your blower is all that takes to solve that kind of noise.
Step 4 – Lubricate the Rod
Listen to the noise that your electric fireplace produces. Usually the kind of noise can help you diagnose the problem. If it is a squeaking noise then probably the inside rod need lubricating. To do this, simply open up the back panel of your electric fireplace. You will then see the rod. Just lubricate this rod with industrial oil.
Step 5 – Check the Internal Circuit Breaker
For certain electric fireplaces that start up and then shut off completely, the problem may lie in your internal circuit breaker. In order for you to completely diagnose the problem, you will need to use a multimeter to find out exactly how much power the unit is utilizing. You will find in your manual the amount of power the unit needs. If your multimeter reading is above that figure, your electric fireplace might be drawing in more power than it can.
Step 6 – Check the Limit Switch
A defective limit switch will turn on, overload and then shut down in a bid to cool down the entire system. If your electric fireplace turns on but then shuts down a few minutes after, then the limit switch could be the culprit. To fix this, open the unit up and check for round disks that has 2 wires. The round disks will only open and close with specific temperatures. Go ahead and replace the round disks.
