How to Make a Profit Buying Foreclosures
Foreclosures represent a large potential opportunity for many investors. When there are many foreclosures on the market, investors can potentially make substantial amounts of money. Here are the basics of how to make a profit buying foreclosures.
Step 1 - Find a Realtor
Start out by locating a realtor that specializes in foreclosures. Find someone who has direct access to the real estate market and can help you locate the best deals. Many of the best foreclosures are distributed to a real estate agent's clients before they go onto the open market. Therefore, if you develop a good relationship with a successful real estate agent, they will be able to help you tremendously in your search for properties.
Step 2 - Look at Properties
Once you have found a good real estate agent to work with, you need to start looking at properties. Do not look at one property and then stop the process. You need to look at multiple foreclosure properties in order to make sure that you find the best deals. You can start out by looking at properties online or through pictures. Then when you find one that you like, you need to venture out to the property and see it firsthand.
Step 3 - Look For Undervalued Property
When you are looking at properties, you need to make sure that you look for property that is undervalued. You do not want to look at the properties that are on the high end of the market for foreclosures. You need to be a bargain shopper when it comes to finding a foreclosure to purchase.
Step 4 - Determine the Price
Once you have located a property that you believe would be a good deal, you need to make an offer. If you are dealing with a property that has been on the market for a while, there is a good chance that the bank will be willing to negotiate. Therefore, you can submit a bid that is lower than the price that is listed.
In some cases, you may have to work with an auction format. Many lenders will hold auctions on foreclosed properties in order to liquidate them quickly. Regardless of the case, you want to make sure that you do not overpay for the property. You need to keep in mind that your money will be made on the front end of a transaction. Therefore, you need to try to get the lowest price that you can.
Step 5 - Fix the Property
After you have taken possession of the property, you should start fixing it up. Ideally, you would like to only make cosmetic repairs to the property. For example, if you can change the carpet, paint the walls, and make the outside of the house look better, this would be the best case scenario.
Step 6 - Rent or Sell
After you have repaired the property, you will need to start renting it or sell it. Many people will rent the property for a specific period of time and then eventually sell it for profit.
