How to Make a Raised Flower Bed with a Stone Border
what you'll need
- Pencil, paper and paper
- Gloves
- Tape measure
- Stakes
- Garden hose
- Shovels
- Level
- Tamper or plate compactor
- Cold chisel
- Baby sledge hammer
- Pea gravel
- Regular blocks
- Special blocks
- Cap blocks
- Soil
- Flowers
You can quickly create a sturdy and natural looking raised flower bed with a stone border using interlocking concrete blocks. Landscape and garden supply stores carry these blocks in a variety of shapes, sizes, surface textures and finishes. The interlocking nature of the block allow for the simple dry stacking. Some blocks incorporate a stair step design feature into the interlocking mechanism. Raised flower beds require less kneeling and bending than flower beds on the ground.
Step 1- Choose Your Block
Find the dimensions of the block you choose. Make note of any special interlocking technique or device. Also make note of any stair case options or specialty block, such as corner blocks, curvy blocks and cap blocks. Lastly, make note of any manufacturer’s installations requirements such as minimum foundation depth or maximum wall height.
Step 2- Lay Out
Choose a level area and lay out your raised flower bed with stakes or garden hose, remember that a larger area requires more blocks. Measure the perimeter in inches and divide the perimeter by the width of the block. The quotient equals the number of blocks per course that you need. Increase or decrease the perimeter of your flower bed to a whole number of blocks. Plan a minimum of two base courses and a finish course. Do not exceed the manufacturer’s maximum height.
Step 3- Create A Foundation
Cut out sod and dig a trench 6 inches deep, 16 inches wide, and level. Compact the earth and add 3 inches of compacted pea gravel.
Step 4- First Course
Choose a spot to begin and lay out the first course of block such the face of the block meets the outer edge of the trench, burying the first course of block about 3 inches. Adjust the blocks if needed to complete the circuit, then lightly pack pea gravel in between and behind the blocks.
Step 5- Second Course
Stagger the second course over the first such that the joints of the second course are in between the first course. Deploy the interlocking mechanisms as required. Crack a block in half with a cold chisel and baby sledge hammer if necessary, to complete the circuit. Lightly pack pea gravel in between and behind the blocks. Add more courses, if desired, up to the manufactures maximum height while lightly packing pea gravel in between and behind each course.
Step 6- Finish Course
Finish the final course off with cap blocks.
Use pea gravel on the bottom of the flower bed to promote drainage. Mix up some soil, plant your favorite flowers, and watch them grow.
