Login Error
Close
How to Make a Ranch Style Wooden Sign
by DoItYourself Staff
what you'll need
  • Old or rustic looking board
  • Saw
  • Router
  • Wood stain
  • Paint brush
  • Sandpaper
  • Paper and pencil or marker
  • Scissors
  • Picture hanging kit
  • Wood clamps
An authentic looking ranch style wooden sign can add a bit of rustic nostalgia to any room. You can create a welcome sign for your porch or doorway, or even make individual signs for the kids' rooms. The possibilities are endless and this simple step by step how-to guide will tell you everything you need to know.
Step 1 - Cut Sign to Size
Determine how large you want the wooden sign to be. For a welcome or family name sign, 8 x 16 inches is a good size, or 3 x 6 inches might be more appropriate for a child's bedroom door. However, the size is up to you. Measure and mark the piece of wood, and then cut the wood to the desired size.
Step 2 - Create Stencil
Take a piece of paper and a pencil and create a stencil for the wording of the sign. You can use stencil letters to make the letters or draw them freehand. With a ranch style wooden sign, it is not so important to make sure that the letters are straight or evenly spaced. In fact, experiment with stencils that use offset spacing or even letters that are of different heights. Cut out the letters on the paper with a pair of scissors.
Step 3 - Draw Stencil on Sign Board
Trace the stencil lettering onto the piece of wood with a pencil.
Step 4 - Route the Sign Wording
Insert a half-inch straight bed into your router. Then, secure the sign board to a work table with the clamps. Next, slowly route over the pencil marks that you made for the stencil letters. If you stray from the mark slightly, don't worry about it. Mistakes often give more character to rustic ranch style wooden signs.
Step 5 - Route the Edges of the Sign
Change the bit in the router and use a rounded corner bit. Then, route around the edges of the sign board to give it a beveled or curved edge.
Step 6 - Sand the Sign
Sand the entire surface of the sign board. Sand the front and back of the piece of wood. Sand the wood until it is smooth and there are no rough edges.
Step 7 - Stain the Sign
Use the paintbrush and apply stain or varnish to the wooden sign. Apply the stain or varnish in very light coats and keep all of the brushstrokes in the same direction. Allow the stain or varnish to sit for about 15 to 20 minutes in between coats. Apply three to four coats for the best finish. If you will be hanging the sign outside, you may want to consider applying a few coats of polyurethane to provide additional protection for the sign.
Step 8 - Attach Picture Hanging Kit
Use the screws and wire provided in the picture hanging kit and install it on the back of the sign. Now the sign is ready to be installed in the location of your choice.
 forum activity
