How to Make a Spiral Metal Garment Rack
what you'll need
- Metal bar
- Caster or furniture wheels
- 29-ball spiral rack
- Tripod, four way connector, or metal plate
- Drill and bits
- Screws
- Screwdriver
- Clamps
- Measuring device
- Ruler
- Pencil
- Paint
- Paintbrush
Spiral metal garment racks could add attitude to any clothing display. Notice that clothing boutiques have spiral metal garment racks placed strategically on some spots of their business area. It is because the intricate design of these garment racks add or modifies the bland appeal of standard clothing racks. You could also use a spiral metal garment rack to add a dash of personality to key points of your room. You can easily set up or build your own spiral metal garment rack. To ensure your project’s success, follow the steps below.
Step 1 – Measure the Area You will Place the Spiral Rack
Check the dimension of the areas where you plan to place your spiral metal garment racks. Line the areas with a pencil and ruler to get accurate measurements. The numbers you get will let you assess if a 29-ball spiral rack will fit in. Lessen the size of the spiral rack for small spaces.
Step 2 – Create the Base
If you are using a metal plate, start measuring the center of the area where you would install the metal bar or stand. Drill a hole at the center to insert the bar. Attach the bar to the base by using screws and clamps. In the case of tripod or four-way connectors, simply attach the bar to the top hole.
Step 3 – Attach Caster Wheels
Consider assembling caster wheels at the bottom of the rack’s base. Do this by driving screws and drilling holes on the base as needed. Installing wheels will give you the benefit of moving your spiral rack to different locations.
Step 4 – Install the Spiral Ball Rack
Notice that the spiral ball rack has a curved design. This comes in with clamps that could be used to adjust the height of the ball rack. Clasp one end of the ball rack at the top end of the bar. Swing it until it falls to the exact spot where the other end should be clasped. Clamp it on the exact location.
Step 5 – Adorn or Paint Your Spiral Rack
Add more attitude to your spiral rack by infusing appliqués, or painting it your desired color.
