Login Error
Close
How to Make Leaf Mold Compost
by DoItYourself Staff
what you'll need
  • Rake
  • Leaves
  • Compost storage unit
  • Water
Leaf mould compost is a type of compost that is made from green and brown leaves and does not contain any other garden or kitchen waste, such as twigs or vegetable peelings. Unlike other compost types, leaf mold compost does not add any additional nutrients to soil, but it can increase water retention by up to 50 percent and improve the soil's overall structure. Leaf mould is carbon based and will not omit any odors. It can be achieved in gardens of any size. Leaf compost can be used as organic mulch or as a bedding base for other plants. The process for making leaf mould compost is very simple, but the finished product can take up to 12 months to complete.
Step 1: Preparation
Before gathering any leaves together, run a lawn mower over them to break them into smaller pieces. This has the added benefit of introducing a small amount of grass cuttings to the compost pile, which will speed up the composting process slightly. This is because grass cuttings act like an accelerator in compost piles, adding some additional moisture.
Step 2: Storage
There are several different storage methods that can be used for producing leaf mould compost. Leaves can be enclosed in a wire mesh, put in a large plastic bag or placed into a wooden container such as a standard compost bin. Each method will prevent the leaves from being blown away and help to maintain a high level of heat which is necessary for the decomposition process. Once a storage unit has been selected, use a rake and gather all the leaves together into a corner of the garden, then place the leaves into the unit.
Step 3: Aeration
All compost piles need aeration or air flow to facilitate the break down of the organic materials. If the leaves are in a compost bin or contained within a wire mesh, it will need to be turned on a monthly basis. If the leaves are contained in a plastic bag, make several slits in the plastic to allow the air to flow. The more often a compost pile is turned or shaken, the quicker the materials will break down.
Step 4: Moisture
Add moisture to the leaf pile to assist with the heating and cooling process which will take place inside the leaf mold compost pile. If the storage unit is not enclosed, place a cover over the leaf mould pile to maintain moisture levels and prevent the pile from drying out or becoming too wet during harsh weather conditions. The compost pile will need to be checked regularly to ensure that the moisture level is adequate.
Step 5: Uses
Once the leaf mould has taken on a soil texture it can be used in the garden. Leaf mould can be dug into soil beds to aide with water retention or it can be added to flower beds and vegetable patches as mulch.
 forum activity
