Login Error
Close
How to Make Sheer Roman Shades
by DoItYourself Staff
what you'll need
  • Measuring tape and pencil
  • Sewing machine
  • Sheer fabric and thread
  • Dressmaker's scissors: sharpen before using
  • Clear plastic rings, 1.2 mm cord, cord acorns
  • Tissue for hem
  • Velcro hook and loop tape
  • Purchased header rail, cut to size
Sheer roman shades are among the easiest styles of shades to make. They suit the relaxed, balloon or cloud styles best due to their light weight and fluid texture and there's no need to insert dowels. Learn how to make sheer roman shades using the directions below.
Step 1: Measure the Window for Hanging
Measure inside the window frame from the top underside to the window sill. Measure the fabric adding 1 inch per side to the width and 2 inches to the top and bottom edges.
Step 2: Measure the Fabric for Fullness
For a plain, relaxed shade cut the fabric to the dimensions shown above. For a balloon shade, use fabric twice the width of the window. For a cloud shade cut the fabric to 3 times the window width.
Step 3: Sew in 3 of the 4 Edges
Sew in hems along the long side edges, 1 inch wide. Sew in a top hem 2 inches deep for the header attachment. At the bottom, make a generous hem sleeve 2 inches deep, and leave the sides open. This hem will be stuffed with tissue for each of the 3 shade styles.
Step 4: Prepare the Top Hem for Attaching to the Headrail
For the relaxed roman shade, sew on the hook side of the velcro strip. For the balloon shade, gather the top hem by pulling and distributing gathers across 2 hand basted pull cords 1 inch apart, till the hem is the same width as the headrail. Tie off the threads, and snip off the excess gather thread. Sew on the velcro hook side of the strip as above. Fold in and pin box pleats for a balloon shade every 3 inches across the top hem and stitch them down with the sewing machine. When the bottom hem for each is gathered as desired, stuff in the tissue to maintain the shape of the hem, and sew the open edges closed.
Step 5: Attach the Lifting Components
For each type of shade, attach the bottom plastic ring for lifting to the hemline of the bottom edge. Attach the plastic rings directly to the relaxed shade with doubled thread, in horizontal rows 8 to 10 inches apart, up to the hemline of the top edge. On a balloon shade, fold in and pin the center crease, and sew the plastic rings onto it. Sew the other 2 sets to the stitched edge of the outer hem on each side. Align them side to side, and vertically. On a cloud shade, attach the 2 outer edge sets of rings as for the others, and sew on the rings in 2 columns up the 2 folds of the central pleat. This shade will have 4 strings. Thread the rings with cord upward to the top ring. Attach the shade by its velcro strip to the velcro strip on the header rail, secure the pull strings to the cord acorns and test the shade for smooth action.
 forum activity
