cancel
community forums
comments
How to Make Your Vacuum Cleaner Smell Good
Your vacuum cleaner can help to keep your home smelling fresh by getting rid of dirt and other particles lodged in your carpet and on your floor. However, if you do not regularly maintain it, a vacuum can begin to contribute to the mess in your house by emitting a foul smell. Follow these simple instructions to learn how to make your vacuum cleaner smell good all the time.
Tools and Materials Needed:
  • Vacuum bags
  • Vacuum filters
  • Cinnamon
  • Baking soda
  • Perfume pads
  • Cleaning cloth
Step 1 – Clean the Vacuum
The first step is to start with a clean vacuum. Dampen the cleaning cloth and wipe down the entire surface of your vacuum to remove any dust on it. Change your vacuum bag and continue to replace the bag every 2 to 3 months regardless of whether it is full or not. If you use a washable bag for your vacuum, clean it thoroughly. If you have a vacuum with a disposable bag, replace the bag.
Step 2 – Change the Filter
Filters in a vacuum cleaner work to keep dust, dirt and allergens out of the air. It is recommended that you change your air filter every 3 to 6 months to keep your vacuum in optimal shape. Follow the instructions provided with the air filters to change the air filter on your particular vacuum model.
Step 3 – Insert Perfume Pads
Buy perfume pads for your vacuum cleaner. Select a scent that appeals to you and place the pad as instructed over the top filter of your vacuum. Once the vacuum is turned on, the perfume pad will deliver a gentle scent into the air as air passes through it.
Step 4 – Add Cinnamon
Sprinkle a small amount of cinnamon either into the vacuum cleaner bag or into the debris compartment. The strong smell of cinnamon will counteract the smell of the particles that the vacuum picks up to provide a fresh scent. If you do not like cinnamon, try any number of other sweet smelling food items like coffee beans or dried orange rind to pre-fill your vacuum and providing some level of odor protection.
Step 5 – Add Baking Soda
Sprinkle 1 teaspoon of baking soda into your vacuum bag or your vacuum’s debris compartment. As an odor neutralizer, baking soda will prevent bad smells from coming out of your vacuum. Make it a habit to add 1 teaspoon baking soda and cinnamon every time you change your vacuum bag for the best results.
Use this simple method to get rid of smells from your vacuum and begin using your vacuum to freshen up your home instead of just clean it. Select perfume pads that appeal to your senses and enjoy the sweet smell of clean in your home every day. Be creative and use your favorite natural scents to pre-fill your vacuum canister to have a really unique scent in your home and have the peace of mind that your home is clean and fresh.
Member Comments
Did It Myself! Project
Wainscot Solutions
updated by Starry Eyed
September 5, 2010
Flagstone Patio
updated by Olag00
September 3, 2010
