How to Miter Cut Shoe Molding
A well executed shoe molding installation can make ordinary base molding seem extraordinary. In order for your project to qualify as professional grade you’ll need to pay particularly close attention to the miter cuts.
In order to make precise miter cuts for shoe molding you’ll need the following tools:
- Tape Measure
- Miter Saw with 80 Tooth Blade
- Pneumatic Nail Gun & Compressor
Step 1 – Mark the Shoe Molding
The key to professional-looking miter cuts is taking accurate measurements from corner to corner. Make sure the blade of the tape measure is tight to the inside or outside corner and record the measurement to the sixteenth of an inch. Mark the measurement with a fine tip pencil taking care to keep the line at a 45° angle.
Step 2 – Make the Miter Cut
Use the miter saw to make the cut. Remember to keep the blade to the outside of the mark. This will account for the width of the saw blade when making the cut. If this important step is overlooked, the cut will often be short of the desired length. It’s also important to use a fine tooth blade when making this cut, so as not to splinter the shoe molding.
