Login Error
Close
How to Mount an Overhead Gun Rack in a Vehicle
by DoItYourself Staff
what you'll need
  • Overhead gun rack
  • Drill
  • Metal drilling bit
  • Electric screwdriver
  • Tape measure
If you are an avid hunter, an overhead gun rack is almost a necessity for your car. The following article will show you how to mount and overhead gun rack.
Step 1 - Find Center
Being off from center can cause a problem when storing your guns. Use the tape measure and measure the length and the width of the ceiling. Mark the spot that is between both measurements.
Step 2 - Pilot Holes
You will most likely have to drill into metal, which makes a pilot hole crucial. If, however, you have a layer of wood or cardboard between the main area and the ceiling, you can skip this step. Hold the overhead gun rack assembly in place. Use the drill and create a hole smaller than the screws that came with the overhead gun rack. Use the holes in it as your guides.
Step 3 - Fastening the Overhead Gun Rack
Place one screw in a side and fasten to the ceiling and place another in the other side. You can now install the rest of the screws and the gun clips according to the instructions.
 forum activity
