How to Mount Electrical Boxes to Drywall
what you'll need
- Pencil
- Stud Finder
- Drywall Saw
- Utility Knife
- Screwdriver
- Electrical Box
- 1 inch Wood Screws
- Drywall Screws
Electrical boxes come in different shapes and sizes. You can mount an electrical box to a drywall in your home without the help of a professional electrician, this will help you save money and give you the satisfaction of being able to do the job yourself. With the right tools and instructions you will be well on your way to mounting electrical boxes to a drywall in your home.
Step 1: The Location
Choose the place you want to mount the electrical box and find the nearest stud.
Step 2: Mark the Center of the Stud
Use the stud finder to find the stud and mark the center of the stud and locate the next stud. Studs are normally installed 16 inches from each other.
Step 3: Wires or Pipes in the Wall
Check carefully if there are any wires or pipes in the wall. If you are using an electronic stud finder, you will be able to easily locate any metal in the wall. This will help you to be careful when you cut the wall.
Step 4: Draw the Outline
Remove the electrical box from its packaging and trace its outline with a pencil on the wall. Make sure you do this between the two studs.
Step 5: Cut the Wall
Use the saw to carefully cut into the wall. If you cut along the design you traced on the wall, you will have a neat hole in the wall.
Step 6: Attach the Wires
If there are wires in the wall, attach them together and push them to the side to allow the electrical box to fit into the hole you cut in the wall.
Step 7: Fix the Mounting Brackets
Use the mounting brackets that came with the electrical box and fix it to the electrical box.
Step 8: Mount the Box
Mount the electrical box to the studs using the 1-inch wood screws. Make sure the screws are screwed down well so that the electrical box is fixed firmly. Use the mounting brackets to fix the electrical box to the studs.
Step 9: Fix the Screws
Use the screws provided to fix the electrical box firmly to the dry wall.
Step 10: Gasket & Waterproof Plate
If you are mounting the electrical box on a wall outside, you will have to use the gasket and waterproof plate to make sure it is properly insulated. If you mount your electrical box indoors, you can use a PVC box and will not need to use a gasket and waterproof plate.
Step 11: Wiring
Install the receptacle if you are doing the wiring also. Once you have done that make the proper wire connections.
Step 12: Close the Box
Use the cover that came with the electrical box and close it securing it with the screws provided.
That is all there is to mounting an electrical box to a dry wall.
