How To Mount Outdoor Home Security Cameras
what you'll need
- Drill
- Screwdriver
- Pencil
- Ladder (If Installing in a High Location)
For many homeowners concerned about home security, one answer to their worries is to install outdoor home security cameras. Today's home security cameras can be installed at almost any location around your home, from inside a lighting fixture to a corner of your eaves to hiding place in landscaping, and can be an effective watchdog for your home and belongings.
If you're planning to install an outdoor home security camera, you can accomplish the job with just a few simple steps, often in a matter of an hour or less.
Step 1 - Pick a Position
Decide where you want to mount your home security camera, including which direction you want to point it, along with the angle and height of the camera.
Step 2 - Mark the Spot
Mark the position of the mounting bracket.
Step 3 - Drill Pilot Holes
Using a drill bit slightly smaller than the screw you will use to install the bracket, drill a hole into the wall.
Step 4 - Install Mounting Brackets
Secure the mounting bracket into place with the mounting screws.
Step 5 - Set the Camera
Place the security camera into the mounting bracket.
Step 6 - Power Up
Plug the camera into a power source or install the batteries.
Step 7 - Sychrnoize with the Receiver
Synchronize the camera with the receiver/base station according to the manufacturer instructions.
With your new camera in place, you will now have an excellent new layer of security at your home.
