How to Paint a Concrete Basement Floor
what you'll need
- Safety Glass
- Latex Gloves
- Mask
- Cement Caulking
- Dehumidifier
- Vacuum Cleaner
- Sand Paper
- Damp Cloth
- Chlorine Bleach
- Paint Roller
- Paint Primer
- Latex Paint
- Stain Blocker
Painting your concrete basement floor is a good home improvement project that you can do with your kids. Concrete basements are used in various ways other than as a storing old furniture and stuff. In painting your concrete basement floor, safety is an important matter. Make sure to open all the doors and windows in your basement prior to painting for good ventilation. You also need to wear mask and other protective gears, as you will be exposed to the noxious fumes of paint primer, chlorine bleach, stain blocker and latex paint. Below are the materials that you need along with the instructions on how to paint a concrete basement floor.
Step 1-Check your Basement Flooring for Dampness
Check your basement flooring for any dampness. This is an essential step that you must do before proceeding with painting your concrete basement floor. Make sure that there are no puddles of water or damp spots on your basement. Repair the cracks on your basement floor with cement caulking. You can also use a dehumidifier to remove the dampness in your basement.
Step 2-Check your Basement Flooring for Smoothness
Check the smoothness of your concrete basement floor. With sand paper, even out the rough concrete basement flooring. After sanding, make sure to remove the dust residue before proceeding with the next step with a vacuum cleaner. Wipe away the remaining dusts with a damp cloth.
Step 3-Clean the Concrete Basement Floor
After making sure that your concrete basement floor is smooth, even, and free of dampbess, clean your concrete basement floor. Remove the dirt on the floor using a scrub brush and ordinary detergent. Remove the stains on the floor with a 6 ml of chlorine bleach diluted in ten cups of lukewarm water.
Step 4-Apply Paint Primer
Make sure that your concrete basement floor is completely dry and clean before applying the paint primer. With a paint roller, apply two thin coats of primer. Allow the first coat of paint primer to dry before applying the second primer. If you want to hasten the drying period of the paint primer, you can also use a humidifier.
Step 5-Apply Stain Blocker
After the paint primer is completely dry, apply a thin layer of stain blocker on your concrete basement floor using a fresh paint roller. The stain blocker will support the primer and make sure that the latex paint that you will apply on the next step adheres to the paint primer well.
Step 6-Apply the Latex Paint
With a fresh paint roller, apply a single, even and thin coat of latex paint on your concrete basement floor. Allow the latex paint to dry completely. Apply another coating of latex paint. You can also add as many latex paint coat as you want, depending on your preference. Just make sure to allow the previous coat to completely dry before adding another coat of latex paint.
