Login Error
Close
How to Paint a Sliding Window Frame
by DoItYourself Staff
what you'll need
  • Sandpaper
  • Filler
  • Drop cloth
  • Masking
  • Primer
  • 1-inch paintbrush
  • Paint
  • Paint cleaner
  • Tack cloth
Painting a sliding window frame isn’t a difficult job. It does, however, take some thought to carry out the task without running the risk of the painting the shut so it can't be opened or closed. With a little time and preparation, you can easily paint a sliding window frame. Gather the common tools below and follow these easy steps.
Step 1 - Prepare
Inspect the sliding window frame for any holes or depressions in the wood. Use filler on these then sand down smooth with the wood. Sand the paint to roughen it, making sure you cover all the frame and the sash properly with sandpaper. This will help the new paint to adhere properly.
You also need to check that the window opens and closes smoothly. If there are any problems with this, take care of them all before you begin painting. Use a tack cloth to remove any sawdust and dust from the sliding window frame. Apply masking tape to the window glass to avoid having to clean up any mistakes. You can just peel it off when finished. If any paint goes beyond these, clean up with minderal spirits or scrape off.
Step 2 - Start to Paint
To begin, you need to have both windows partially open. Lay down your drop cloth below the window. Open the can of primer and use your 1-inch brush to paint the rear sash’s inside frame, as well as the bottom half of the front sash and the bottom of the window frame where the sash would rest when closed. Once you have completed that, paint up the side tracks to just below the sashes.
Make sure you use long brushstrokes that follow the grain of the wood. Don’t overload your paint brush with paint or you’ll just encourage drips and runs.
Step 3 - Front Sash
Change the positions of the sashes around. You’ll now be able to paint the rest of the inside frame of the lower sash on the sliding window frame. You’ll also be able to paint the top of the window frame where the sash rests, known as the rebate, and the top half of the front sash. Paint the tracks at the top of the window to just above the sashes.
Step 4 - Finish the Sill
By now, you should have painted both the upper and lower sashes of the sliding window frame with primer. It’s time to move on to the window sill. Start with the sill’s underside, then paint the top of the sill and move up around the frame. Give the primer ample time to dry and apply your finish coat just as you did for the primer. You’ll achieve the best result by using a silk or gloss vinyl paint for your finish coat because it will wear longer.
Once the final coat of paint has dried, use glass cleaner and a paper towel to clean the glass in the window to a shine. This will set off the new finish on the sliding window frame.
 forum activity
