Login Error
Close
How to Paint a Stove Exhaust Hood
by DoItYourself Staff
what you'll need
  • Dawn dish soap
  • Small bucket of hot water and a sponge
  • Rubber gloves
  • 150 grit sandpaper
  • 1/2 inch paintbrush
  • Small paint roller
  • Paint tray
  • Step stool
  • Primer Paint
  • Damp Cloth
  • Oil base paint
  • Sealant
  • Painters tape
If you are wondering how to paint a stove exhaust hood, take a deep breath and relax because it can be accomplished with a minimal amount of work. Equipped with some basic supplies and a little bit of elbow grease, this job can be completed easily within an afternoon.
Step 1: Clean and Sand the Hood
The first thing you will need to do is mix the Dawn dish soap with the bucket of hot water. A sponge is preferred to cleaning the hood because the texture of the sponge works more efficiently than a cloth. Dawn is the best choice for detergent as it takes away thick layers of grease better than other detergents. Make sure your step stool is in a solid position for the sake of personal safety. The step stool will help to eliminate any pulled muscles or tendons by reaching out of your range. Scrub the sponge repeatedly over the exhaust hood and use the damp cloth to wipe away the excess water. Once the grease is gone and you have allowed the hood to dry, then it is time to sand. Use the sandpaper repeatedly going over the entire hood but avoid putting too much pressure on the metal. You do not wish to scar the metal and simply want to rid the hood of any old paint or grime. Once the sanding is done, wipe the hood with a damp cloth and let it dry.
Step 2: Prime and Paint
This step is a simple procedure that only requires good attention to detail. Use the painter’s tape and tape off all the outside edges. Once this is accomplished, you can pour the primer into the paint tray and use the paint brush to get the edges and the trim of the exhaust hood. After the trim is finished, use the roller to complete the priming process. Make sure you use even and light rolls to help eliminate excess paint bubbles. Apply two layers of primer and let it dry as per instructions on the can. While the primer is drying, clean your paint brush and tray and fill it with the oil base paint in the color of your choice. Using the same method you used for the primer, use the brush the trim and then use the roller applying two separate coats of oil paint. Oil paint will prove to be easier to clean and will remain more durable than a water based product.
Step 3: Seal and Dry
Using a clean roller, apply two layers of sealant once the oil base paint has dried as per product instructions. The sealant is a necessity to prevent water damage, rusting, mildew or chipping. Put away your supplies and avoid cooking for 24 hours on your range top to give your exhaust hood a chance to properly dry before it is exposed to steam. If you don't wait the allotted time, you could end up having to start over from the beginning.
 forum activity
