How to Paint a Swirl Plaster Ceiling
Painting a plaster ceiling with a swirl plaster finish or texture is a full day process, unless you have a power sprayer. This article is going to list some methods of applying paint to a textured plaster ceiling and some things to be sure to do to make cleanup as easy and effortless as possible.
Remove the Current Texture
Some may want a smoother surface to apply paint to. If you scrape the larger pieces of texture off the ceiling, you should be able to maintain the basic pattern, while still being able to use a standard paint rolling system and obtain full coverage.
Apply Over Texture
If you don’t want to smooth out the better part of the current texturing, the ideal application tool is going to be an airless sprayer, similar to a Wagner Powerpainter. Your next option is to roll the paint on, but you’ll have to keep the paint thick on the roller to make sure all of the texture receives paint, even in the valleys and crannies.
Things to Do to Help with Cleanup
There’s only a few things to do to really help make sure cleanup is quick and easy.
- Remove all furniture from the room
- Apply and tape down a layer of painter’s paper or butcher’s paper.
- Lay a painter’s tarp over the paper.
- Tape and paper off the top 8 to 12 inches of the walls.
