How to Paint a Tin Ceiling
what you'll need
- Sandpaper
- 2 to 3 inch wide paint brush
- Drop cloth
- Latex paint for 2 coats
- Rolling pan
- Paint roller
- Lambswool roller head
- Artist brushes for detailing
- Acrylic varnish
Painting a tin ceiling is a fairly easy project because many tin celings already have a coating of primer. Many pre-fabricated tin ceilings have designs stamped into them, some of them rather ornate. It is recommended to use lighter or neutral colors to paint this type of ceiling; many tin ceiling designs cast shadows that become too deep if a darker color is used.
Step 1 - Clean and Prime Ceiling
Wipe down the ceiling panels with a damp rag to remove any surface dirt. If you find any small rust spots, carefully sand them away.
Step 2 - Roll on Paint
Use a lambswool roller to apply a good quality latex paint; lambswool will spread paint into all crevices of the ceiling pattern. Apply 2 even coats and be sure to allow even drying time in between the first and second ones.
Step 3 - Add Detailing and Varnish
If you are painting a tin ceiling with decorative patterns and want to bring these out, apply paint to them in a complementary color with a smaller detailing brush. These kinds of brushes can be found in many sizes at art supply stores. Once all paint is dry, brush on a protective coat of varnish to prevent paint chipping.
