How to Paint a Vinyl Fence
what you'll need
- Epoxy-based exterior paint
- Exterior primer
- Sealant
- Garden hose
- Bucket
- Mild detergent
- Wash cloth
- Drying towel
- Latex gloves
- Brush
- Paint roller or sprayer
- Safety goggles
- Dust mask
- Plastic cling wrap
Although they are often installed as a maintenance-free option, there may come a day when you wish to paint your vinyl fence. Since vinyl fencing is more durable than regular wood fencing, keep in mind that its longer warranty could become void if you paint your fence and damage its surface. However, if your fence has faded over the years or you have grown tired of the color, painting it can be as simple as staining a wooden fence.
Step 1 – Purchase Correct Materials
Vinyl fencing is a smooth surface that will not absorb regular latex or oil-based paints. You will need an epoxy-based paint that adheres to the vinyl. You will also need to make sure your painting tools are right for the job. Using the wrong brush or roller will cause uneven application, thus creating messy drips in the finish. Ask your local DIY store for brushes and rollers that will work with epoxy-based paint.
Step 2 – Prepare Fence
Even if you hose down your vinyl fence on a regular basis, there will still be a layer of dirt and grime that can prevent epoxy-based paint from adhering properly. Use a bucket of warm, soapy water to thoroughly wash your fence before rinsing it off with the garden hose. Take the time to dry off your fence with a clean towel as this will remove any residue that might affect paint adhesion. Let the fence dry before priming.
Step 3 – Apply Primer
Priming your fence properly will ensure that your paint does not crack or bubble prematurely. Use an exterior primer designed for vinyl products that is also mold and mildew resistant. Wearing latex gloves, use a brush to fill out tricky angles and a roller to cover the larger areas of your vinyl fence. A paint sprayer will give you a more even finish and covers the same area in about half the time as a roller (Remember to wear safety goggles and a dust mask if using a paint sprayer). Allow the primer to dry before painting.
Step 3 – Apply Paint
Paint your vinyl fence using the same method as priming. If you are using the same paint spryer, make sure you clean it thoroughly and allow it to dry so primer and water are not mixed with your epoxy-based paint. Wrap brushes and rollers with plastic cling wrap instead of cleaning them between applying coats of paint. Let the paint dry between coats and before applying a sealant.
Step 5 – Apply Sealant
Protect your newly painted fence by applying a high-gloss sealant. A good sealant will protect your fence from the elements and keep the paint from cracking or fading. Putting a protective coating on your vinyl fence will ensure that you are able to enjoy the maintenance-free benefits that vinyl fencing offers for many years to come.
