cancel
Job type :
Zip Code :
community forums
comments
How to Paint a Wall in 4 Steps
Learning how to paint a wall is a fun and a rewarding task that can be shared with your whole family. Follow the steps below to get started in painting a wall in your home.
Step1-Gather the Necessary Materials
You will need the following materials to get your project off the ground:
  • 1 large paint bucket;
  • 1 metal screen for the bucket;
  • 1firm bristled brush;
  • 1 one roller;
  • 1 can of primer (unless your walls are white in which case you won't need to prime);
  • 1 roll of plastic poly;
  • 1 roll of painter's tape;
  • 1-2 pieces of sand paper, and;
  • 1 can of paint.
Step 2-Before You Prime
Use the plastic roll of poly and some blue painters tape to cover and protect the floor and any valuables near the wall you intend to paint. Take down any art work that may be on the wall. Use the painter's tape to cover the corners of anything you don't want paint on like the window or mantle.
Step 3-Prime Your Wall
Use the hard bristled brush to edge the wall. Edging the wall means that you should paint a 8-10 inch wide margin around all corners. This will make it easier to be accurate with the roller. Once you have edged and rolled the entire wall in primer, wait for it to dry thoroughly and then sand it. Run the sand paper up and down the entire wall until it is smooth and shiny.
Step 4-Paint Your Wall
Follow the same steps for painting as you would for priming. Edge the wall's corners, windows, and anything else that may be risky to use the roller near. Once you have completed the edging, use the roller on the rest of the wall. Don't forget to run the roller along the metal screen in the paint bucket, this will keep your work clean and even. Depending on the thickness of your paint and your personal color preference, wait for the paint to dry, sand it once more, and then paint again. Always use at least two coats and three at the most for the best results.
member comments
Related Articles
9 Steps to Painting like a Pro
A guide to painting like a professional. It includes all the steps necessary to paint... read more
How to Maintain a Home
Tips for making various repairs around the home... read more
Questions About Painting Difficult AreasQuestions About Painting Difficult Areas
Answers to members' questions about painting technique and indoor painting projects... read more
articles we like
Comprehensive Health Care
Comprehensive health care in the United States is among the best in the world. There... read more
Making Over the Porch for Greater Curb Appeal
Making over the porch successfully can be done to suit a variety of budgets as... read more
Don't Let Back-to-School Stress Show Up On Your FaceDon't Let Back-to-School Stress Show Up On Your Face
Back-to-school time is one of the most stressful times of the year for teens. Here's... read more
sponsored articles of the day
diy centers
