How to Paint Foam Crown Molding
what you'll need
- Foam crown molding
- Paint, preferably latex
- Brushes (or roller brushes with an extended handle for painting near walls and ceilings)
- Paint tray
- Paint brush cleaner
- Newspaper
- Painter's tape
Painted foam crown molding can be a relatively affordable and effective way to enhance the look of your walls and ceilings whether you're looking to brighten a room or add sophisticated accents. Below are some tips on the tools, materials and steps you need to complete this colorful redecorating project.
Step 1 - Prepare Paint Workstation
Begin by selecting the paint color of your choice—latex paint tends to work best for this project. Foam crown molding is ready to paint and does not require any primer applications. Select a clean, medium-sized brush to paint pre-installed molding, or use a roller brush for material that is already in place. Cover your work area, such as the floor and walls, with taped newspaper or other disposable material.
Step 2 - Paint Foam Crown Molding
It's easier to paint foam crown molding prior to installing it. In this case, lay sections of the material on the newspaper, face side up. Paint with 1 or 2 coats, and then allow to dry before installing. For pre-installed molding, coat a roller brush with paint that is poured into a paint tray.
Next, use the roller brush to apply the paint to the installed foam crown molding. Finish by cleaning the brushes with paint cleaning product.
