Login Error
Close
How to Paint over Horsehair Plaster
by DoItYourself Staff
what you'll need
  • Paint roller with 1 1/2-inch nap
  • Desired paint and primer
  • Rolling pan
  • Floor covering
If you're living in a house with horsehair plaster, you know the general issues that come with it. One of these issues arises when you want to paint over your horsehair plaster. Follow the guide below to make that task a bit easier.
Step 1 - Prepare the Walls
If there are any cracks in the horsehair plaster (as there often are), make sure that you fix them prior to painting. Sand down any bumpy areas and wipe the walls down to ensure you get rid of any dust.
Step 2 - Prime the Walls
Once you have a smooth set of walls, use the roller and your primer to coat the walls thoroughly. This step will allow the paint to stay on more easily, and it will save you coats later on.
Step 3 - Paint the Walls
Using the same roller (washed out) or a new one, apply the paint to the walls. Move in a "V" formation so you don't leave lines on the walls. Allow each coat to dry thoroughly before you apply the next. You can also opt for wallpaper if you'd like, but note that it will be more difficult to take down in the future.
 forum activity
