How to Paint over Semi Gloss Paint
what you'll need
- Electric Sander
- Sandpaper
- Step stool
- Drop cloth
- Safety glasses
- Dust mask
- Tack cloth
- Paint primer
- Paint
- Paint roller
- Paintbrush
- Painters tape
- Screwdriver
If you want the rooms in your home to pop and sizzle with vibrant colors then semi gloss paint is most definitely the only paint choice you would have. Semi gloss paint is one of few paint choices you will find that is shiny and can reflect off itself. The problem that many people have with semi gloss paint is that it is a pain to use. You have to create a very clean surface, prime it with two costs then start applying semi gloss paint. Semi gloss paint is prone to streaking and that is natural but it is also thinner than other paints and therefore is runnier. This usually translates into botched paint jobs and also the reason why semi gloss paint needs to be applied in several coats. The great thing about semi gloss paint is that it does make a wall pop but it is also easy to clean. It is this one point that makes painting over semi gloss paint difficult. Semi gloss paint repels water so you can wipe it down and wash it but getting other paint to adhere to it is tricky but this article will show you how.
Step 1 - Sanding the Wall
Semi gloss paint is very smooth and shiny and it repels water. This means it needs something that isn't there: texture. Move furniture from the walls and out of the room. Place a drop cloth over furniture you cannot move. Cover the floor with a drop cloth and put on your dust mask and safety glasses. Gently sand the wall u sing very little pressure over the entire wall then use the tack cloth to remove dust.
Step 2 - Getting Ready to Paint
Now that the semi gloss paint is textured you can get ready to paint. Place painters tape around the edges of the wall so you don't paint the ceiling, floor or another wall you don't want to change. Use the screwdriver and remove light switches, light fixtures or outlets that may be present on the wall you are painting. The last things you want to add to the shopping list are new fixtures and covers.
Step 3 - Primer
Even though the semi gloss paint is textured and can be painted it is still fairly bright. This shine can show through a coat of matte paint. Primer paint is typically a dull white although you can buy primer in various colors to interact with top coat of paint. Begin painting the edges of the wall and around outlets and switches using a paintbrush. Use a roller to apply the rest of the primer and allow it to dry prior to applying another coat.
Step 4 - Top Coat
Wait for the primer to dry for a day then apply the first coat of the paint. There's no special way to apply the top coat. Once it is dry another coat of paint can be added if you think it’s needed.
