Login Error
Close
How to Paint Vinyl Shutters
by DoItYourself Staff
what you'll need
  • Paint (spray can)
  • Screwdriver
  • Styrofoam cup
  • Soap
  • Sponge
  • Scrub brush
  • Safety goggles
  • Gloves
  • Breathing mask
  • Sawhorses
Your vinyl shutters now look worn and faded after years fighting off the elements. They are in a desperate need for a overdo facelift so you are contemplating the best method to get a fresh, new look. You could hire a professional painting contractor to get the look you want. However, the task is not as hard as you may think. With the right tools, a bit of time and some valuable know how, this can be a project you can accomplish on your own.
Step 1 – Preparation
Prepare the area where you will work, making sure to provide enough ventilation when spray painting. You should wear a breathing mask, protective safety goggles and gloves when conducting your vinyl shutter facelift. You do not want to run the risk of inhaling any toxic paint spray or fumes. Make sure the area is clear and that any fixtures in the vicinity are removed or covered to protect anything from errant paint spray.
Also, select a shady spot to help accelerate the curing of the paint.
Step 2 – Select the Paint
Make sure to select a type of paint that is suitable for exterior purposes that will adequately protect your vinyl shutters as well as color theme. There are specific paints formulated for many vinyl and plastic surfaces that would be well suited to this task. You can check out different brands and colors at your local paint store or home improvement center or do the research on Internet. A good hint is to select a color a shade darker than the house exterior walls to establish an aesthetic color scheme.
Step 3 – Remove Your Vinyl Shutters
Do not attempt to paint your exterior vinyl shutters while they are attached to your home. Remove them carefully by unscrewing them from the wall. Be careful not to damage the vinyl shutters during removal. Place the vinyl shutters on a pair of sawhorses before proceeding. Carefully retain the hardware used to attach the shutters by placing it in a Styrofoam cup and marking the contents on the outside.
Step 4 – Clean the Vinyl Shutters
Thoroughly wash the vinyl shutters using a mild soap with a sponge. Employ a stiff bristled brush to attack any stubborn areas to dislodge dirt and grime. Make sure to properly rinse the vinyl shutters and allow sufficient drying time.
Step 5 – Paint the Vinyl Shutters
Using the spray paint you selected, apply layered coatings using long and sweeping motions to ensure even application. To prevent dripping do not stand the shutters on end to paint. Place them flat on the sawhorses where you can spray in a side-to-side motion.
Step 5 – Allow Curing Time
Although it may appear that the paint is drying quickly, allow several days for it to harden sufficiently. Keep the shutters in the shade or bring them indoors. Allowing several days for curing will help to increase the life expectancy for the paint applied.
Step 6 – Replace the Vinyl Shutters
Once the vinyl shutters have cured, replace them carefully.
 forum activity
