Login Error
Close
How to Perform a Power Steering Flush
by DoItYourself Staff
what you'll need
  • Car jack
  • Jack stands
  • Hose
  • Container
  • Socket wrench
  • Nutdriver
  • Screwdriver
If you have had some recent power steering problems, then a power steering flush is going to be needed in order to have the system work correctly. Since the power steering works with the build up of pressure in the liquids in the system, flushing it and making sure the fluids are correct is going to make controlling your care much easier. If you have never done a power steering flush before, the process can be easily done in your own garage. Here are the tools to use and the steps to take in order to perform your own power steering flush.
Step 1 - Park Car on Level Surface
Since you will be jacking your car up to perform a power steering flush you must find a level, and clutter free, area to park the car. Your garage is the best place, but if you need to do this outside, make sure it is a level area.
Step 2 - Locate Power Steering Assembly
Open the hood of you car and look into the engine compartment. On the driver's side you will notice the steering column. Close to this is a long hose that contains the power steering fluid. You will find the filter at the top of this system. Once you locate the filter, you will need to remove it.
Step 3 - Remove Overflow Tank
To get at the power steering assembly easier you will need to remove the overflow tank from the radiator. As you are removing the tank you can also remove the power steering reservoir's hose. Wiggle the hose back and forth after you loosen the clamp. This can be on there pretty tight, so a little patience is required.
Step 4 - Replace Hose
When you remove this hose, it is a good time to replace it with a new one. Leave one end free so it will travel into an empty container. This container will capture all of the old power steering fluid as you flush it out.
Step 5 - Jack up Car
Set the emergency brake on your vehicle and start to jack up your car. Raise it enough so you can get under it comfortably. Set jack stands on the frame to ensure your safety while under it.
Step 6 - Add Power Steering Fluid
Start to pour in new power steering fluid into the reservoir. As you pour in the new fluid you will notice that some of the old fluid will begin to travel out the hose into the container.
Step 7 - Work Steering Wheel
Making sure your steering wheel is locked you will then move it back and forth. You do not want a large amount of motion in this. You only want to move it a little in each direction.
Step 8 - Watch Container
As you move the steering wheel it will force the old steering fluid out of the reservoir. Continue watching the container until you see the new fluid starting to flow through.
Step 9 - Replace Hoses
Now that the old fluid has been flushed from the system you can replace the hose from the container to the power steering assembly. Replace the overflow tank and pour fill up the power steering reservoir with fresh fluid. Lower the car and replace the filter onto the power steering pump.
 forum activity
