How to Pick the Best Snow Tires for Your Vehicle
Snow tires are an important feature to have, if you are driving in winter conditions. The type of snow tire you purchase will depend on the make and model of your vehicle, and the weather conditions in your area.
Reading Your Owner's Manual
Read through the owner's manual provided by the manufacturer of your vehicle. The manual will outline requirements for the size and type of tire you need.
Low to Mild Temperatures and Small Amounts of Snow
If you drive your vehicle in areas where you experience temperatures around freezing and small amounts of snow, you should consider all season tires. These tires perform well throughout the entire year.
Low to Mild Temperatures and Average Amounts of Snow
Consider the weather in your area. If you drive your vehicle in areas where the temperatures are typically above freezing, consider high performance winter tires. These tires perform well on dry surfaces.
Lower Temperatures and Large Amounts of Snow
If you drive your vehicle in areas where the temperatures can reach much lower ranges, and you experience a fair amount of snow, you should consider severe winter tires. These tires perform well in snow covered surfaces.
Lower Temperatures, Large Amounts of Snow and Ice
If you drive your vehicle where you experience very low temperatures, large amounts of snow and icy conditions, consider studded snow tires. There are typically laws regarding these tires, so be sure to verify that they are legal in your area. There tires perform well in severe winter conditions.
