Login Error
Close
How to Pickle Stain Knotty Pine
by DoItYourself Staff
what you'll need
  • Pickling Stain
  • Clean Rags
  • Foam paint brush
  • Polyurethane
  • Natural bristle paint brush
  • Sandpaper (120-grit and 220-grit)
  • Tack cloth
Choosing to pickle knotty pine is a great way to highlight the unique grain and imperfections in the wood. Pickling is a staining technique that can be done with either a pre-mixed pickle stain, or a self-prepared mixture. Either way, the process of pickling knotty pine is exactly like staining any other wood surface.
Step 1 - Prepare Surface
If this is an existing piece, remove existing finish entirely. Sand the surface with 120-grit sandpaper. Wipe clean with tack cloth.
Step 2 - Pickle Surface
With a foam brush, apply pickling stain to the knotty pine. Be sure to force stain into all grains on the surface. Let the pickling stain sit on the surface for 5-minutes, wipe excess stain off with a clean rag. If any of the areas are not sufficiently stained, repeat the process. If the stain is exceptionally thick in any area, remove more stain as desired. Allow stain to dry for 24 hours.
Step 3 - Finish Surface
After pickling stain has dried completely, apply 1-coat of polyurethane with a natural bristle brush. Allow the polyurethane to dry for 24 hours. Lightly sand the surface with 220-grit sandpaper. Apply another coat of polyurethane. Continue until the desired finish is achieved. Allow final coat to dry at least 48 hours, and then enjoy your pickled knotty pine piece.
 forum activity
