How to Place a Solid Surface Shower Pan
A solid surface shower pan is a worthwhile investment especially if made from quality materials. Quite often, the cost associated with the labor of replacing a damaged or worn shower pan can exceed the cost of buying a new one.
Here are several key items you’ll need for proper installation:
Plywood
Create the floor by placing a 3/4-inch piece of plywood over the top of 2-by-10 inch joists. Cover the plywood floor with slip sheet held in place by wire mesh and staple both materials to the plywood.
Bottom Flange and Clamp Drain Assembly
Assemble the bottom flange of the clamping drain assembly and pour a latex additive into a wheelbarrow and mix thoroughly.
Shower Pan
Place the shower pan line directly on top of the mortar bed and fold any excess of the liner at each corner of the pan. Staple the highest section of the liner securely.
Deck Mud
Fill the area with deck mud and pack using a trowel. Make sure the drain and weep holes are clear. This will prevent having to do the job over again.
Taking the time to do the job correctly the first time around can save a lot of time and money.
