How to Plant and Grow Rose of Sharon
what you'll need
- Rose of sharon plant
- Shovel
- Water
- Mulch/fertilizer
Also known as Hibiscus Syriacus, rose of sharon is a lovely ornamental shrub that blooms in the summer months, growing to a height of 8 to 10 feet. It requires minimal maintenance, grows slowly and has a natural resistance to pests. For these reasons, it is a favorite among both hobby and master gardeners. The rose of sharon flower is a soft white with maroon center--a simple yet elegant bloom. Planting a rose of sharon tree is a fairly easy task that will only take you a little time. Once completed, you will enjoy your new addition for years to come.
Step 1: Determine Planting Location
Find the best place for your rose of sharon plant. It likes full sun but also does well in a partially shady area. Don’t crowd it too much because it needs room to grow.
Step 2: Dig the Hole
With your shovel, dig into the dirt to the depth of the root system of the plant and 2 to 3 times as wide as the transplanting pot.
Step 3: Transplant the Rose
Gently tap the container on the ground until the roots and soil loosens up a bit. Carefully remove the plant from its container and place it upright in the ground. Before you refill the hole, fill it with water and let the plant absorb the water completely.
Step 4: Refill the Hole
Use the dirt you dug out to refill the hole. Make sure the plant becomes secured in the refilled dirt. Gently tamp down the dirt to stabilize the rose of Sharon. Water it again until the ground around the plant is soaked.
Step 5: Apply mulch
Liberally apply mulch or other organic fertilizer around the stem in an area large enough to cover the disturbed dirt. Apply mulch to a depth of 2 to 3 inches all the way around the plant.
Now that your rose of sharon plant is in the ground, you will need to water it frequently. Be careful not to over-water it! A waterlogged plant will begin to show yellow leaves because you are suffocating the roots. The soil in which you planted the rose of sharon should drain well. If drainage becomes a problem, you can transplant the rose of sharon to an area that drains properly. Try mixing peat moss into the soil to increase drainage. Because the rose of sharon does not require a tremendous amount of maintenance, it does not need to be watered daily. Keep an eye on the soil to see when it gets too dry. When the plant is young, water it 3 times weekly. As it matures, reduce it to 2 times weekly. A well-established plant might survive with 1 good weekly watering although that will depend largely on the region in which you live. If you get a lot of rain, let nature do the work.
