Login Error
Close
How to Polish Bathroom Countertops
by DoItYourself Staff
Bathroom countertops can be the secret to adding a touch of class to your bathroom. The best way to polish a bathroom countertop will vary depending on the type of material from which it is made. Most countertop materials—wood, granite, marble, tile—are not impervious to scratches, stains and smudges. Common ingredients to reach for around the house that double up as polish agents are orange juice, nail polish remover (because of the acetone), vinegar (for the more stubborn stains) and bicarbonate of soda.
Water-based Cleansers
Marble countertops need the most care. Polishing these involve using a water-based cleanser and a piece of cloth. Do not use acid-based products or abrasive materials like steel wool as marble is sensitive and can be damaged in a matter of minutes.
Plastic laminated countertops are the easiest to polish. First use a scrubbing pad and water to loosen any smears. Now apply a polishing cleanser using a wet sponge, rubbing gently as you go along.
Surface Polishers
Commercial surface polishers, like lemon Pledge, are the best choice for wooden countertops. Spray this on and use a soft piece of cloth to spread it about. You will achieve a shiny finish as well as a pleasant spring scent.
 forum activity
