Login Error
Close
How to: Polish Silver Jewelry
by DoItYourself Staff
what you'll need
  • Shallow dish
  • Aluminum foil
  • Salt
  • Baking soda
  • Clean towel
Silver jewelry polish is easily available in the market and can be used to polish your silver objects. Although the polish is easily available, it can be difficult to maintain and a little expensive. There are several home remedies that can help you polish your silver jewelry that has lost its shine and texture due to tarnishing. Use this step-by-step guide to learn one very popular technique of doing the job. The tools and materials required for the job are given below.
Step 1 – Prepare the Silverware
First, prepare all the silver jewelry you want to polish. The trick is to set them up on a lining of aluminum foil in the dish. It is imperative to make sure that the jewelry objects are placed far from each other and not overlapping each other. This will ensure that when you add baking soda, each object is evenly coated. When you have placed the jewelry, sprinkle baking soda over them.
Step  2 – Boil Water
Next, take some water in a pan. You have to take enough water so that you can cover the silver jewelry in the dish that you want to polish. When you have taken enough water, bring it to boil on a flame. Add salt during the boiling process. When the water has boiled for a while, pour the water over the silver jewelry.
Step 3 – Finish the Job
When you have poured the boiling water over the silverware, mix the silver jewelry around with a wooden spoon. Do not use a metal spoon as it can coat the silverware too. When the objects have cooled down, you will notice that they are shiny and without tarnish. Take them out and wipe with a dry cloth to shine them even more.
 forum activity
