Login Error
Close
How to Prevent Drywall Dust Build Up
by DoItYourself Staff
what you'll need
  • Plastic sheeting
  • Tape
  • Fans
  • Wet-Dry equipment
Any building project can create large amounts of drywall dust. By being especially careful, you can reduce the amount of dust you will need to remove when the building project is complete.
Step 1 – Covering the Room
Use tape to secure plastic sheeting to the doorways of the room being built or rebuilt. Use a heavy plastic sheeting product, to prevent any tearing or ripping.
Step 2 – Suctioning Dust
Suction dust out of the windows with a fan. The fans will need to be positioned so that they blow the air, and drywall dust, out of the window.
Step 3 – Wet-Dry Equipment
There are a variety of sanders and saws that can be attached to a wet-dry vacuum which will send the drywall dust directly into the vacuum compartment. If you do not have any of this type of equipment, it is readily available at the hardware store.
Step 4 – Wetting the Surfaces
Lightly wet the surfaces in the room before you begin to work on the building project. This will prevent the dust from moving through the air. Be careful using water around electric equipment.
Step 5 – Cleaning Work Clothes
The dust on your work clothes can be transported throughout the house. Remove and clean the clothes you are working as quickly as you can.
 forum activity
