Login Error
Close
How to Prevent Mold On Walls from Spreading
by DoItYourself Staff
Mold on walls can be unsightly and ruin the appearance of your home. It may also be toxic and cause you and your family health problems. Additionally, mold infestation can significantly downscale the value of your home. Accumulation of dirt, wet and humid conditions are common causes of mold development. It can be quite a challenge to clear mold, especially once it develops extensively on your walls. Not only will removal call for a lot of effort, but the financial cost may also run pretty high. It is best to deal with mold as soon as you spot it. Follow the simple guidelines below.
Clean Regularly
Mold typically develops and spreads faster on dirty surfaces. This is because dust and dirt make a conducive environment for the development of mold spores. Obtain natural mold cleaners from the market to clean your walls once dirt begins to show. These cleaners effectively clear mold and also contain ingredients that prevent the amplification of mold. Natural mold cleaners have no harmful effects on plant life when they drain off the wall and into the soil. This makes them a good choice if you have environmental concerns.
Address Water Leaks
Unchecked water leakage is a common accelerator of mold problems. Leaks in your pipe work can cause water infiltration into the walls which results in mold and encourages its spread. Be on the lookout for rust or condensation around pipes as this indicates a water leakage. If you detect a musty odor from any of your walls or have toilets or faucets that drip, it is best to attend to these immediately. Inspect your roof for any leaks as roof leakage introduces excessive moisture into the walls which facilitates spread of mold. Seal all leaks to prevent further damage and development of mold.
Seal Windows
Loose seals around the windows encourage air leaks. This leads to condensation which encourages growth of mold. It is a good idea to use a sealant around windows that are not completely airtight. This will help prevent excessive moisture and check the spread of mold.
Gutters
Check your gutters periodically to ensure they’re not clogged or faulty. With time, dirt and debris tends to accumulate in rain gutters. Inefficient gutters allow water to seep into the walls and the foundation of your home. You can easily clean your gutters with the aid of a broom or garden hose. It helps if you cover your rain gutters with perforated covers available at hardware stores. This will help to keep away much of the dirt and debris that otherwise finds its way in. Clean, unobstructed gutters go a long way to check water seepage and help to contain the spread of mold on walls.
Humidity Control
It is important that you monitor the relative humidity in your home. When it exceeds 55 percent it is likely to lead to excessive moisture on your walls and encourage mold. It is a good idea to get a hygrometer to help you monitor the relative humidity. Once you establish that the relative humidity exceeds 55 percent, you’ll need to use a dehumidifier to regulate the humidity. Regular dehumidification helps to prevent the spread of mold on your walls.
 forum activity
