Login Error
Close
How to Prevent Mold on Your Basement Ceiling
by DoItYourself Staff
what you'll need
  • Air conditioner
  • Dehumidifier
  • Humidity monitor
The basement ceiling is one of the premier spots to find mold in your house. This is because mold forms in cold, damp areas and the lack of ventilation and sunlight provide a perfect environment for mold growth. However, that doesn't mean that you should resign yourself to having a moldy ceiling, there are steps that you can take to prevent its formation.
Step 1 - Moisture Control
The key to mold prevention maintaining a dry basement. If you suspect that you have mold you need to find anything that could be causing moisture to form or pool in the basement area. Be sure to check any carpeting and all of the perimeter walls. If you find any areas of water ingress you must make sure that you deal with them properly to prevent the mold from returning.
Step 2 - Air Circulation
If you have any windows you could open them to increase the air circulation. If you don't have windows, then the use of an air-conditioner or dehumidifier can also help to dry the area out. Portable units are available from shops and rental companies if you don't want to install a permanent one, e.g. if you just need to dry the room as a one-off process and don't intend to use it frequently.
Step 3 - Leaks from Above
The most common place to find mold on a basement ceiling is underneath an area where water is frequently used in the house above, e.g. under a kitchen or bathroom. If you have a problem with leaks from any of the water pipes or appliances in your home be sure to check the basement ceiling periodically for mold.
If possible you should also check and/or replace any insulation materials in the floor/ceiling cavity, as leaving them damp will encourage mold growth. Mold will typically begin growing within 4 days, but if it is in the cavity you may not notice it until much later. Install exhaust fans in your bathrooms and kitchen to cut down on the moisture that remains in those rooms.
Step 4 - Humidity Monitor
Hardware stores stock humidity monitors that you can install in your basement to monitor the ambient moisture. Ideally you should aim to keep the humidity level below 60 percent to prevent mold growth.
Step 5 - External Water
If the ceiling of your basement is at ground level, then another factor that could lead to mold growth is standing water around the perimeter. Make sure that all downspouts from gutters are in good condition and expel their water into a drain and not just directly into the soil around your home. If you have a driveway or a concrete slab at the side of your house you should ensure that they are on a slight slope (at least 1 inch for every 10 feet of width) so that any rainfall will run away from the walls rather than being encouraged to pool there.
Step 6 - Insulate Pipes
Insulate any pipes that run across your basement ceiling to prevent condensation forming on them during summer months when the air temperature is warmer. Also check around the point where the pipe enters the basement from above for any sign of mold.
 forum activity
