How to Prevent Rotting in a Wood Retaining Wall
what you'll need
- Green foundation-grade treated wood
- Brown foundation-grade treated wood
- Wood preservative
- Paint brush
A wood retaining wall is a simple, attractive and easy-to-build tool for converting steep slopes and awkward hills in your yard into usable, easily navigable land. Wood retaining walls can help you turn those slopes into attractive, terraced planting beds for flowers, herbs or vegetables. The materials are fairly cheap and light. Sounds perfect, right? Well, almost; wood retaining walls aren’t without their flaws, the worst one being that they are prone to wood rot. The constant contact with wet soil and the exposure to humidity and the elements puts the wood at risk. Keep in mind that the risk for rot will be highest in humid climates with a high precipitation rate, so if you live in such an area, you will definitely want to shell out more dollars to keep your wall protected than if you live in a mainly dry, sunny environment. The best way to prevent rotting in a wood retaining wall is to treat the wood prior to installation. Keep reading to find out more about how to prevent rotting in a wood retaining wall.
Step 1: Order the Best Wood
The best way to prevent wood rot in a wood retaining wall is to start with the highest quality materials possible. Although builders often use “ground contact” rated wood for these types of walls, your best bet to have a truly protected wood retaining wall is to use foundation contact wood, and in particular, pressure-treated wood. This is wood that has been treated to withstand under-ground conditions, like the humidity from soil, and so it’s perfect for this type of purpose. However, on the downside, it is more expensive and typically harder to find than other grades of wood, so depending on your area you may have to do some hunting to find it. Redwood and used rail ties are also good, weather resistant options.
Step 2: Double Treat It
Even though you’ve already got the treated wood, you should double protect by treating it with wood preservative. This will form an even tougher barrier that will really keep the moisture and the rot out for a good long time. Wood preservative is available at any major hardware store. Apply it to the wood with a paint brush according to manufacturer’s directions. You can also use creosote, which helps to keep the insects away, or weather sealer.
Step 3: Form a Barrier
Another way to help stave off the rot is to try to form a protective barrier in between the treated wood and the soil. This can easily be accomplished by stapling a water resistant tarp to the side of the wood wall that will be in contact with the soil. Another possibility is to build a mini retaining wall of stones or pebbles that lies in between the wood retaining wall and the earth.
