How to Program One Remote for All Home Entertainment Needs
In this world of electronics you need to be able to take control of your home entertainment system. A universal remote control is one way to do so. For nearly every piece of electronic equipment you have there is most likely a remote control that goes with it and that can get confusing. Do yourself a favor and get rid of all of those remote controls because it is easier than ever to make all of your home entertainment components work with just a single remote control.
Select the Right Universal Remote Control
It may seem as simple as heading off to a store and grabbing the first remote that you see but it is not. Picking the right remote control for your needs can go a long way in saving you money, planning for future growth and making sure you can even use the universal remote control. Keep in mind that new technology is constantly being developed and this means that universal remote controllers are also on that same path. It is a good idea to make sure the universal remote you want is made by a third party manufacturer. This ensures that you will be able to get updates product codes and adjust your remote accordingly over the years to come. When you are shopping for a remote you should also keep in mind the components you have to control and make sure they are represented on the universal remote.
Playing Component Number Tag
This may be the most frustrating part of programming a remote to use it for all of your components. Some items do not have codes but other codes from other companies may work. First, try the codes in the booklet that came with your universal remote. If your specific brand is not listed under the brand section then try the codes, one at a time, until you either find one or determine that none work. You can attempt to use codes from other brands but your best shot is
