Login Error
Close
How to Properly Apply Enamel Paint
by DoItYourself Staff
what you'll need
  • Enamel Paint
  • Primer
  • Brushes with Nylon or Synthetic Bristles or Rollers or Sprays
  • Sealant
An enamel paint can be either oil-based or water-based. It is thick and can be used for a hard surfaced, glossy finish. This shiny and durable paint sticks well to almost all surfaces and can be used for almost all purposes like art and craft or painting furniture.
Applying enamel paint can be tricky. However, once the art is perfected, enamel paint has advantages that remain unmatched by many other types of paint. The article discusses how enamel paint can be applied effectively.
Step 1: Arranging the Workplace
It is important to find the right workplace. Ensure the place chosen will allow the paint to air dry fast and has ample ventilation. Breathing enamel can be harmful as it contains many harmful chemicals and toxins. Thus, free-flowing air is important to prevent suffocation. In addition to this, the place must restrict small children and pets from coming close. Safeguard all nearby places with an old piece of cloth or paper.
Step 2: Cleaning the Surface
Once the location is ready, clean the surface that needs to be painted with the help of a primer. The surface must be clean from all debris and dust free. Apply a coat of primer to help safeguard it and make it durable by keeping it away from warping, rusting, or molding. In addition to this, it ensures the surface remains smooth and glossy after the enamel has been applied.
Step 3: Painting the Surface
Once the primer dries, you can continue painting the surface. Use a clean brush that is free from all dust and other elements. Use a turpentine to rinse the brush so that it is absolutely clean and no doubt remains. Dip the end of the brush into the paint container and wipe off all excess paint. Start painting at the center and work your way outwards. This allows you to concentrate on the most visible areas of the surface. Continue on to do a second coat if needed.
Step 4: Finishing
Once the enamel paint is applied, apply a layer of sealant. Sealant is a glutinous substance that gives the surface a solid and complete finish. It protects and shields the painted surface from the external environment like smoke, dust, air particles, etc. that may stick to it and damage it. Avoiding this step could result in a discolored, chipped, rusted, or damaged surface.
Step 5: Drying
Allow the surface to air dry. Enamel paint dries very quickly and should not take more than an hour. However, it is good to keep the surface untouched for a few hours to ensure complete drying and releasing all smell of the paint.
Step 6: Cleaning
Clean the surrounding area. Enamel paint, when dried is very hard to remove. Thus, it is a good idea to remove wet paint from the area surrounding the surface. Clean the tools properly before storing them as if not done properly, leftover paint may spoil the tool and make it unsuitable to use again.
 forum activity
