Login Error
Close
How to Properly Clean the Track of a Sliding Glass Door
by DoItYourself Staff
what you'll need
  • Miniature vacuum
  • Terrycloth towel
  • Toothbrush
  • Screwdriver
  • Steel wool
  • Tack cloth
  • Lubricating grease
  • Acetone
  • Ladder
When a sliding glass door seems to stick, the resistance to movement is usually caused by dirt, oil and other particles trapped in the track. This article will show you how to properly clean the sliding glass door track.
Step 1 - Removing the Door
You can clean the sliding door track without removing the door, but you would only be cleaning a portion of the track. There are two ways to remove a sliding glass door. The first is by grasping it at each end and lifting upward as you pull it toward yourself. The other is to locate the lower rollers and use the screwdriver to raise them off the track. When you do this, you can then lift the sliding glass door upward and pull it toward you to remove it.
Step 2 - Initial Cleaning
Over time the track of the door can become very dirty. Bits of leaves, bark, gravel and sand are just some of the things that can get on the track and prevent the door from gracefully sliding. Use the miniature vacuum to go over the sliding glass door track to remove any loose materials. Do the same thing with the top and the bottom of the sliding glass door and the top track. Always remember that there are actually four tracks to keep clean.
Step 3 - Rust Removal
The tracks of a sliding glass door are typically made out of aluminum or other weak metal. Most of the time this metal is not treated against rust and so it can develop. This rust can cause the sliding glass doors to not slide correctly. Remove the rust using the steel wool. Once you are satisfied use the tack cloth to remove any metal particles you may have created.
Step 4 - Removing Grime and Oil
It is important to note that the change of temperature as well as the constant opening, closing and bombardment of the elements can cause grime to surface. Oil will often seize and become thick which will hinder the sliding glass door from moving smoothly. To remove this build up of grease and grime you will need to dip the toothbrush into the acetone. Get the bristles soaking wet and begin rubbing the inside of the track both top and bottom as well as the tracks on the door itself. Once the grease has been removed you can wipe the tracks down with a terrycloth towel.
Step 5 - Finishing Up
To allow the sliding glass doors free movement the tracks needs to be greased. Use the lubricating grease and place a small amount along the bottom track and the top track on the sliding glass door. You can now replace the sliding glass doors. Slide the doors several times to distribute the lubrication along the tracks and wheels.
 forum activity
