How to Prune a Japanese Maple Tree
what you'll need
- Safety Glasses
- Work Gloves
- Pruning Snips
- Pruning Shears
- Compost
- Shovel
- Pitchfork
- Garden Rake
Japanese maple trees are popular indoor and outdoor plants. Grown inside, the tree grows into a thick shrub with numerous branches. Outdoors, you can trim the lower branches and shape the crown to tailor the appearance of the tree as it grows.
Step 1: Prepare the Japanese Maple
Fertilize Japanese maples a week before pruning. Remove the mulch from around the base of the tree and add 2 inches of compost. Use a pitchfork to loosen the soil without digging. Poke the prongs into the ground and wiggle the handle back and forth a few times. Smooth the area with a rake, and replace 2 to 3 inches of mulch. Water the area thoroughly.
Step 2: Trim Lowest Branches
If your tree is outdoors, you should probably trim the lower branches. Indoors, trim sagging branches. Use the pruning snips to cut the branches at a 45-degree angle approximately ½-inch to 1 inch from the main stem or branch.
Step 3: Crown Raising
Japanese red maple trees will grow a thick crown if properly pruned. Snip the tips of branches 2 to 4 inches back from the tip, above a leaf or branch juncture. each tip cut off will result in a double tip sprouting at the juncture, adding body and fullness the to crown of the plant.
Step 4: Crown Thinning
Because you are working to make the crown full, trim back inner branches to prevent the limbs from growing into themselves. When thinning the crown, be careful not to remove limbs that are prominent in appearance. Outdoors, crown thinning can be used to shape the crown, say for a more pointed top or one that resembles a ball. How you choose to shape the tree is totally up to you.
Step 5: Touch Up
Examine the tree for broken leaves or branches, and remove them. Look for errant branches poking out at angle that do not help to define the shape you want, and smooth the general appearance. This type of touch-up can be done throughout the growing season of the tree.
Step 6: Composting
Save the leaves and small branches you remove from the tree and add them to your compost bin. recycling yard waste into fertile compost helps your keep your lawn and garden looking its best without purchasing chemical fertilizers or other potentially harmful treatments.
Step 7: Pest Control
Indoors, you can mix liquid dish soap with water and use that as a misting spray for indoor plants of all types to prevent insects. The same process can be used outdoors, and can be supplements with marigolds planted around the base of the tree. If you have a problem with ants, plant a border of mint, and crush a few of the leaves now and then. Mint has been shown to be effective in repelling ants and some other insects.
