Login Error
Close
How to Rebuild Diesel Engine
by DoItYourself Staff
diesel engine is an internal ignition engine, which utilizes heat to burn the fuel and proves to have the highest thermal efficiency of any regular engine, because of its high compression ratio. The average service life of a diesel engine is usually about 10 years and it then needs to be rebuild or replaced from time to time. Thus, rebuilding the diesel engine proves to be a better and a cheaper option, compared to replacing the engine. All you need to do is, follow the steps mentioned below:
Tools Required for Rebuilding the Diesel Engine
  • Hand tools
  • Cloth
  • Wrench
  • Ring compressor
  • Ring expander
  • Gauges
Step-By-Step Instructions for Rebuilding the Diesel Engine
Step 1: Inspecting the Cylinders for Wear and Tear
First step is to check if the cylinders are worn or proper. If they are worn, they need to be polished, so that they are able to accept the oversize rings. But if the cylinders are in a proper state, you can simply just run a shiny finish down and perform the work by yourself.
Step 2: Seat Re-facing Equipment
Second thing to do is to check if you have seat re-facing equipment or not. If not, you need to sort that out first. The worn guides can be replaced or fixed with the help of some special tools at home. But on the other hand, jobs like line boring, crank refinishing and all has to be done with the help of a professional.
Step 3: Purchase of Engine Rebuilding Kit
You then need to purchase this engine rebuilding kit. It can be bought from any hardware local shop. It consists of the tools mentioned above, with some additional things as well such an oil pump, camshaft, lifters, timing chain and few other supplementary things.
Step 4: Torque to Yield Head Bolts
Figure out if your diesel engine has the torque-to-yield head bolts. If yes, then do not forget to replace them because rebuilding this part is very risky for your vehicle engine. You never know how old they are and therefore, you need to have the latest and the finest head bolt torque.
Step 5: Check Guides for Wear and Tear
Also make sure that the guides are not worn. If they are, the diesel engine would end up sucking a lot of oil. This happens mostly when a lot of black carbon air is present on the back of the intake valves in the combustion chambers. Thus, always remember to replace the guides while rebuilding your diesel engine.
Additionally, one of the best reasons for doing your own engine work is that you do not have to worry about the quality of the different parts of your engine. Once the engine is bought from outside, you are not able to control the quality of all the parts, as you do not if it is of top quality or not, you cannot decide that. Thus, it is better you rebuild your own engine by yourself, if possible. It would prove to be much cheaper and better for you, if you have the right knowledge to perform the task.
 forum activity
