Login Error
Close
How to Reface a Cabinet Door
by DoItYourself Staff
what you'll need
  • Screwdriver
  • Sander
  • 80 Grit Sand Paper
  • 160 Grit Sand Paper
  • Wood Putty
  • Paint Remover
  • Stain Remover
  • New Hardware
  • New Finish Material
Refacing a cabinet door is one of the easiest ways to change the look of your kitchen. These remodeling projects can save you a lot of money, without having to go into a major renovation project. There are a lot of different projects around the home that a homeowner can do themselves. Refacing their cabinet doors is one of these projects. While the work is not difficult, it will take time for the chemicals to work; figure about three days from start to completion.
Step One - Remove Cabinet Door
Using your screwdriver, remove the cabinet door from the cabinet face. While you have the door off, you should also take off all the hardware off the door. This will include the hinges, handles, pulls, or anything else that might be attached to the door.
Step Two - Set Door in Well Ventilated Area
You will be working with some very strong chemicals, that have a powerful odor. You will need to be working in a well ventilated area. A garage, outside, or in a basement with fans and open windows are great places to work. You should not work inside the home unless you have to.
Step Three - Apply Removal Chemicals
Set the door down on a flat surface and apply either the paint remover of the stain remover. If there are several layers of paint you will have to do this a few times. However, after the chemical has been applied you will need to let it set and let the chemical work.
Step Four - Scrape Off Paint
Once you see that the paint on the cabinet door has started to bubble you can begin to scrape it off. Use a wide bladed scraper and take off as much as you can. If there is still a lot of paint on the cabinet door then you can re-apply the paint remover.
Step Five - Sand Off Rest
Using gradually increasing grit of sandpaper you should sand the entire cabinet door down to the bare wood.
Step Six - Fill In Any Holes
Apply wood putty to any parts of the cabinet door that will need to be filled in. You want a smooth surface for your cabinet door without any holes or gouges. Roll up a small amount of putty between your fingers and press into any holes. Once the putty has dried you can sand it smooth.
Step Seven - Repaint Cabinet Door
Once you have cleaned off the cabinet door and dried it completely you can now repaint the surface of the door. Add a primer coat first and then add your paint. If you are going to stain the cabinet door, you should wipe it on with a soft cloth and apply as many coats as you need to get it to the desired color.
Step Eight - Install New Door
Once the cabinet door dries, you can re-attach the hardware and install back onto the cabinet face.
 forum activity
