How to Reface Sheetrock Walls
what you'll need
- Sheetrock patch
- Plaster or drywall mud
- Drywall tape
- Trough and drywall tool
- Sandpaper
- Razor knife
- Paint
- Paint brush
- Wallpaper
- Stucco compound
This article discusses how to reface sheetrock walls. There may be situations that require you to reface your sheetrock walls. When those situations occur, it is good to understand how to reface your sheetrock walls. Here is a list of the tools and materials as well as steps needed to reface your sheetrock walls.
Refacing your sheetrock requires a few steps, especially if you are patching a damaged area or going for a complete change of the wall. This process should be easy to accomplish and just about any do-it-yourselfer with a free weekend can reface their sheetrock walls.
Step 1: Obtain Sheetrock Supplies
When you have to reface your sheetrock walls, you need to obtain materials in order to accomplish this task. For most refacing jobs, which occur because of a hole or some other repair that needs to be done, you will need a patch for the drywall, plaster or drywall mud and drywall tool. A trowel and tool to spread the drywall mud is necessary as well. All of these materials can be purchased at a home improvement center.
Step 2: Prepare the Wall for Refacing
Clean the wall in order to prepare the surface for refacing. Remove all pictures and any furniture that is leaned up against the wall. Be sure to create a space that is large enough for you to maneuver in while refacing the sheetrock.
Step 3: Repair and Patch Holes
Repair all holes on the sheetrock with the drywall mud, using a trough and drywall tool to spread the mud. Use a razor knife to cut any damage areas of the wall and apply a patch. The patch, depending on the size of the repair may need to be taped, mudded and sanded in order to apply it.
Step 4: Apply Mud or Other Texture to the Sheetrock
If you are looking to create a stucco or other wall effect on the sheetrock as part of your refacing job, apply the mixture as instructed on the packaging. Be sure to first sand the wall and make it smooth and uniform, especially if you have completed a repair of the wall. Apply the compound to the wall evenly with the drywall tool and allow it to dry appropriately.
Step 5: Applying Paint or Wallpaper to the Sheetrock Wall
Once you have applied the compound for a stucco effect or applied a patch of a hole or damage area, paint the wall with a paint color of your choosing. You may also decide to wallpaper the wall in order to create a different look. Follow the instructions for properly wallpapering your wall or applying paint in order to get the desired look.
